MailStore – Outlook is not responding
Summary
In MailStore Server, when opening the MailStore archive by using the MailStore Outlook Add-in, leads to an unresponsive Outlook.
This issue was reported in (but may not be limited to):
  • MailStore Server
  • MailStore SPE
Resolution
Usually one of the following reasons is responsible for this problem:
  • If the MailStore Server is unreachable, it may take up to 60 seconds until the error message occurs. In that case, wait for the error message and reconfigure the connection settings of the MailStore Outlook Add-in if necessary. Adjusting the firewall settings may also be necessary.
  • If an error occurred and the error message lost the focus (e.g. by clicking into the area outside of the message box), there is no way to put the message box into the foreground anymore. In that case, you will need to kill the Outlook.exe process by using the Windows task manager.
